Uscito finalmente 5.3.2 !!!
Messaggiodi roma88 » 4 maggio 2011, 13:34
ragazzi ieri la ubnt ha rilasciato il nuovo firm.
http://www.ubnt.com/forum/showthread.php?t=35073
roma88
Re: Uscito finalmente 5.3.2 !!!
Messaggiodi admin » 10 maggio 2011, 15:13
queste le relase note:
Version 5.3.2-Service Release (May 3, 2011)
- New: AirRouter HP support
- New: Completely remove non 5.7-5.8 GHz frequency for US and Canada country code
- New: Auto Adjust to EIRP Limit replaces Remove Obey Regulatory Rules
Improvements/Change requests:
- Improvement: WPA/WPA2-TKIP security stability improvements in noisy environments
- Improvement: CCQ calculation
- Improvement: AirMax performance
Fixes:
- Fix: Possible memory corruption fix
- Fix: Return Channel Shifting for M900 and M365 products
- Fix: Connectivity issues for some mobile devices
- Fix: Speed test and traffic shaper issue
- Fix: Invalid connection time (49,689 days) reporting issue
- Fix: Send gratuitous ARP reply on bridge MAC change (when starting AirView)
- Fix: MIC errors encountered in high interference case if aggregation is used
- Fix: PPPoE authentication doesn't work through STA bridge with some routers
- Fix: Multicast routing does not work in SOHO-Router mode
- GUI fix: Hide "Auto Adjust to EIRP Limit" checkbox for Compliance test country code
- GUI fix: Disabling "Enable Installer EIRP Control" option, when "Auto Adjust to EIRP Limit" isn't enabled, allows to apply settings without any real changes
- GUI fix: Change warning message, when turning off "Installer EIRP Control"
- GUI fix: Under IE Stations list table header text should not be wrapped
- GUI fix: Site Survey doesn't return scan results in 10 MHz channel width
- GUI fix: Enable Discovery checkbox is not intuitive under "AirControl", move under Service menu
- GUI fix: Report allowed port range when configuring System services
- GUI fix: Site survey does not always return scan results
- GUI fix: Ad hoc device mode in Site survey returns symbols
- GUI fix: Strange TX/RX values in throughput graphic under IE9
- Fix: AirControl agent: Incorrect WLAN connection count reporting
- Fix: AirControl agent: Invalid wlanUptime reporting
